Disassembling Olympus Pen E-PL7
  1. Disassembling Olympus Pen E-PL7, Battery: step 1, image 1 of 2 Disassembling Olympus Pen E-PL7, Battery: step 1, image 2 of 2
    • Turn the camera upside down.
    • Push the grey tab to the right to open the battery compartment.
    • Pull out the battery.
    • The battery is not shown in these photos.
  2. Disassembling Olympus Pen E-PL7, Back Case: step 2, image 1 of 1
    • Use a Phillips #00 screwdriver to remove the six 2 mm screws on the bottom of the camera.
  3. Disassembling Olympus Pen E-PL7: step 3, image 1 of 1
    • Remove the two 4 mm reverse threaded Phillips screws from the bottom of the camera.
    • Reverse threaded screws tighten counter clockwise and loosen clockwise.
  4. Disassembling Olympus Pen E-PL7: step 4, image 1 of 1
    • Remove the two 4 mm Phillips screws under the HDMI port cover.
  5. Disassembling Olympus Pen E-PL7: step 5, image 1 of 1
    • Use a Phillips #00 screwdriver to remove the 5 mm screw near the left hand grip.
  6. Disassembling Olympus Pen E-PL7: step 6, image 1 of 1
    • Use a Phillips #00 screwdriver to remove the 5 mm screw near the right hand grip.
  7. Disassembling Olympus Pen E-PL7: step 7, image 1 of 1
    • Flip open the LCD.
    • Use a Phillips #00 screwdriver to remove the 2 mm screw beneath the LCD assembly.
  8. Disassembling Olympus Pen E-PL7: step 8, image 1 of 1
    • Use a Phillips #00 screwdriver to remove the four 6.3 mm screws from the lens mount.
  9. Disassembling Olympus Pen E-PL7: step 9, image 1 of 1
    Tool used on this step:
    Buy
  10. Disassembling Olympus Pen E-PL7: step 10, image 1 of 1
    • Use tweezers to remove the inner metal ring.
  11. Disassembling Olympus Pen E-PL7: step 11, image 1 of 2 Disassembling Olympus Pen E-PL7: step 11, image 2 of 2
    • Use tweezers to remove the two springs lying beneath the inner metal ring.
  12. Disassembling Olympus Pen E-PL7: step 12, image 1 of 1
    • Use a Phillips #00 screwdriver to remove the three 5 mm screws.
  13. Disassembling Olympus Pen E-PL7: step 13, image 1 of 1
    • Remove the two 4 mm Phillips screws.
  14. Disassembling Olympus Pen E-PL7: step 14, image 1 of 3 Disassembling Olympus Pen E-PL7: step 14, image 2 of 3 Disassembling Olympus Pen E-PL7: step 14, image 3 of 3
    • Press and hold the lens release button while using tweezers to remove the lens hook.
    • Use tweezers to remove the spring underneath the lens hook.
  15. Disassembling Olympus Pen E-PL7: step 15, image 1 of 3 Disassembling Olympus Pen E-PL7: step 15, image 2 of 3 Disassembling Olympus Pen E-PL7: step 15, image 3 of 3
    • Use tweezers to remove the metal clip from the external flash mount.
  16. Disassembling Olympus Pen E-PL7: step 16, image 1 of 1
    • Use a Phillips #00 screwdriver to remove the four 4 mm screws from the external flash port.
  17. Disassembling Olympus Pen E-PL7: step 17, image 1 of 2 Disassembling Olympus Pen E-PL7: step 17, image 2 of 2
    • Remove the second external flash clip with tweezers.
  18. Disassembling Olympus Pen E-PL7: step 18, image 1 of 2 Disassembling Olympus Pen E-PL7: step 18, image 2 of 2
    • Remove the external flash port casing to expose five more screws.
  19. Disassembling Olympus Pen E-PL7: step 19, image 1 of 1
    • Use a Phillips #00 screwdriver to remove the two 6.4 mm screws.
    • Remove the 2 mm Phillips screw.
  20. Disassembling Olympus Pen E-PL7: step 20, image 1 of 1
    • Remove the two 3.8 mm Phillips screws from the sides of the external flash connector.
  21. Disassembling Olympus Pen E-PL7: step 21, image 1 of 1
    • Gently pull the back case away from the camera.
    • Do not attempt to remove the back case, as it is attached to the camera by a ribbon cable.
  22. Disassembling Olympus Pen E-PL7: step 22, image 1 of 3 Disassembling Olympus Pen E-PL7: step 22, image 2 of 3 Disassembling Olympus Pen E-PL7: step 22, image 3 of 3
    • To remove the ribbon holding the back case to the camera, use the pointed end of a spudger to flip back the top bar on top of the ZIF connector.
  23. Disassembling Olympus Pen E-PL7: step 23, image 1 of 3 Disassembling Olympus Pen E-PL7: step 23, image 2 of 3 Disassembling Olympus Pen E-PL7: step 23, image 3 of 3
    • Use tweezers to pull the ribbon out of the connector.
    • Remove the back case.
  24. Disassembling Olympus Pen E-PL7, Disassembling Olympus Pen E-PL7: step 24, image 1 of 1
    • Use a Phillips #00 screwdriver to remove the two 1.6 mm screws near the left hand grip.
  25. Disassembling Olympus Pen E-PL7: step 25, image 1 of 2 Disassembling Olympus Pen E-PL7: step 25, image 2 of 2
    • Once the screws are removed, use two fingers to remove the metal clip.
  26. Disassembling Olympus Pen E-PL7: step 26, image 1 of 1
    • Remove the 2.2 mm Phillips screw near the left hand grip, holding a second metal plate in place.
    • Remove the 1.8mm Phillips screw.
  27. Disassembling Olympus Pen E-PL7: step 27, image 1 of 1
    • Once the screws are removed, use two fingers to remove the metal plate.
  28. Disassembling Olympus Pen E-PL7: step 28, image 1 of 1
    • Remove the two 4.1 mm Phillips screws near the right hand grip.
  29. Disassembling Olympus Pen E-PL7: step 29, image 1 of 1
    • Use a spudger to remove the three indicated ribbon cables from their ZIF connectors on the motherboard.
  30. Disassembling Olympus Pen E-PL7: step 30, image 1 of 3 Disassembling Olympus Pen E-PL7: step 30, image 2 of 3 Disassembling Olympus Pen E-PL7: step 30, image 3 of 3
    • Use tweezers to remove the plastic cover from the two ZIF connectors in the upper left corner of the motherboard.
    • Disconnect both ribbon cables.
  31. Disassembling Olympus Pen E-PL7: step 31, image 1 of 3 Disassembling Olympus Pen E-PL7: step 31, image 2 of 3 Disassembling Olympus Pen E-PL7: step 31, image 3 of 3
    • Desolder the large ribbon cable from the motherboard at the solder points on either side of its ZIF connector
    • Learn more about desoldering here.
  32. Disassembling Olympus Pen E-PL7: step 32, image 1 of 3 Disassembling Olympus Pen E-PL7: step 32, image 2 of 3 Disassembling Olympus Pen E-PL7: step 32, image 3 of 3
    • Remove the 5.2 mm Phillips screw from the top of the right hand grip.
    • Remove the top plate.
  33. Disassembling Olympus Pen E-PL7: step 33, image 1 of 2 Disassembling Olympus Pen E-PL7: step 33, image 2 of 2
    • Remove the sensor assembly from the front case.
  34. Disassembling Olympus Pen E-PL7: step 34, image 1 of 1
    • Remove the two 4.3 mm screws from the front of the sensor assembly.
    • Remove the 6.8 mm screw.
  35. Disassembling Olympus Pen E-PL7: step 35, image 1 of 1
    • Remove the four 1.9mm Phillips screws from the back of the sensor assembly.
    • Remove the 14.5mm Phillips screw.
    • Remove the 3.3mm Phillips screw.
  36. Disassembling Olympus Pen E-PL7: step 36, image 1 of 3 Disassembling Olympus Pen E-PL7: step 36, image 2 of 3 Disassembling Olympus Pen E-PL7: step 36, image 3 of 3
    • Use a Phillips #00 screwdriver to remove the 1.7 mm screw securing the tripod mount to the ribbon cable.
    • Use tweezers to remove the small copper ring underneath the screw.
  37. Disassembling Olympus Pen E-PL7: step 37, image 1 of 3 Disassembling Olympus Pen E-PL7: step 37, image 2 of 3 Disassembling Olympus Pen E-PL7: step 37, image 3 of 3
    • Desolder the red and black wires from the back upper right corner of the sensor assembly.
  38. Disassembling Olympus Pen E-PL7: step 38, image 1 of 3 Disassembling Olympus Pen E-PL7: step 38, image 2 of 3 Disassembling Olympus Pen E-PL7: step 38, image 3 of 3
    • Pull the sensor frame away from the sensor assembly.
  39. Disassembling Olympus Pen E-PL7: step 39, image 1 of 1
    • Remove the 4.4 mm Phillips screw securing the motherboard to the battery compartment.
    • Remove the 3.8 mm Phillips screw.
    • Remove the 3.7mm Phillips screw.
  40. Disassembling Olympus Pen E-PL7: step 40, image 1 of 1
    • Remove the three 3.3 mm Phillips screws at the top of the motherboard.
  41. Disassembling Olympus Pen E-PL7: step 41, image 1 of 1
    • Remove the 3.4 mm Phillips screw from the left side of the motherboard.
  42. Disassembling Olympus Pen E-PL7: step 42, image 1 of 1
    • Remove the motherboard.
  43. Disassembling Olympus Pen E-PL7: step 43, image 1 of 2 Disassembling Olympus Pen E-PL7: step 43, image 2 of 2
    • Remove the battery compartment by hand.
  44. Disassembling Olympus Pen E-PL7: step 44, image 1 of 1
    • Use a Phillips #00 screwdriver to remove the three 2.3 mm screws from the base of the LCD screen.
  45. Disassembling Olympus Pen E-PL7: step 45, image 1 of 2 Disassembling Olympus Pen E-PL7: step 45, image 2 of 2
    • Fully extend the LCD.
  46. Disassembling Olympus Pen E-PL7: step 46, image 1 of 3 Disassembling Olympus Pen E-PL7: step 46, image 2 of 3 Disassembling Olympus Pen E-PL7: step 46, image 3 of 3
    • Remove the two 2.2 mm Phillips screws located on the back of the LCD screen.
    • Use tweezers to remove the top bracket.
  47. Disassembling Olympus Pen E-PL7: step 47, image 1 of 3 Disassembling Olympus Pen E-PL7: step 47, image 2 of 3 Disassembling Olympus Pen E-PL7: step 47, image 3 of 3
    • Use a Phillips #00 screwdriver to remove the four 1.4 mm screws from the back of the LCD screen.
    • Remove the LCD ribbon cable with a pair of tweezers.
    • The cover may simply fall off after the screws have been removed.
  48. Disassembling Olympus Pen E-PL7: step 48, image 1 of 3 Disassembling Olympus Pen E-PL7: step 48, image 2 of 3 Disassembling Olympus Pen E-PL7: step 48, image 3 of 3
    • Carefully lift the LCD screen up and away from the assembly.
    • Do not attempt to fully remove the screen, as it is attached to the assembly by a ribbon cable.
  49. Disassembling Olympus Pen E-PL7: step 49, image 1 of 2 Disassembling Olympus Pen E-PL7: step 49, image 2 of 2
    • Use tweezers to remove the plastic covering the LCD ribbon cable.
  50. Disassembling Olympus Pen E-PL7: step 50, image 1 of 3 Disassembling Olympus Pen E-PL7: step 50, image 2 of 3 Disassembling Olympus Pen E-PL7: step 50, image 3 of 3
    • Use the flat end of a spudger to flip back the black bar on the ZIF connector.
  51. Disassembling Olympus Pen E-PL7: step 51, image 1 of 2 Disassembling Olympus Pen E-PL7: step 51, image 2 of 2
    • Gently pull the ribbon cable out with tweezers.
  52. Disassembling Olympus Pen E-PL7: step 52, image 1 of 1
    • Remove the LCD Screen.
  53. Disassembling Olympus Pen E-PL7: step 53, image 1 of 2 Disassembling Olympus Pen E-PL7: step 53, image 2 of 2
    • Pull the ribbon cable through the hole in the LCD assembly.
  54. Disassembling Olympus Pen E-PL7: step 54, image 1 of 1
    • Remove the four 2.4 mm Phillips screws from the inside of the back case.
  55. Disassembling Olympus Pen E-PL7: step 55, image 1 of 2 Disassembling Olympus Pen E-PL7: step 55, image 2 of 2
    • Pull the LCD assembly away from the back case.
  56. Disassembling Olympus Pen E-PL7: step 56, image 1 of 1
    • You have successfully disassembled the Olympus Pen E-PL7!
Kelsea Weber
19,964 Reputation
32 Guides authored
iFixit Member of iFixit
Staff
140 Members
17,684 Guides authored
Past 24 Hours: 7
Past 7 Days: 24
Past 30 Days: 88
All Time: 11,032
