Introduction
This guide will show the user of this scanner how to take apart the chassis so they can repair inside components.
Loosen the screws on the serial port by turning them counter clockwise by hand.
After loosening the screws, pull the serial port out.
Lift lid to its vertical position.
Pull lid straight up to remove it from the scanner.
Push the blue wedges into crack between the top and the bottom of the chassis.
After placing one wedge into the slit, slide other wedges along the slit to detach the top from the bottom of the chassis.
Go all the way along the chassis until you can lift the upper lid.
Do not fully remove the lid until you remove the ribbon cable attached to the front of the upper lid.
Do this by grabbing the upper lid from the sides and rotating it ninety degrees so it is perpendicular to the bottom lid.
Grab the ribbon cable and gently pull it out of its slot with your fingers.
The upper lid can now safely be removed from the bottom lid.
