Disassembling LG VX8300 Body
  1. Disassembling LG VX8300 Body, Disassembling LG VX8300 Body: step 1, image 1 of 3 Disassembling LG VX8300 Body, Disassembling LG VX8300 Body: step 1, image 2 of 3 Disassembling LG VX8300 Body, Disassembling LG VX8300 Body: step 1, image 3 of 3
    • Power off the device by holding down the red button labeled PWR.
    • Be sure that the phone is powered off before touching the battery to avoid danger.
    • Remove the battery pack cover by pushing down on the solid lines at the top end of the cover. Slide the cover down while still applying the pushing force on the top and remove the cover completely.
  2. Disassembling LG VX8300 Body: step 2, image 1 of 2 Disassembling LG VX8300 Body: step 2, image 2 of 2
    • Place your finger into the semicircle gap on top of the battery.
    • Push down and pull so the battery pops out of the phone.
  3. Disassembling LG VX8300 Body: step 3, image 1 of 3 Disassembling LG VX8300 Body: step 3, image 2 of 3 Disassembling LG VX8300 Body: step 3, image 3 of 3
    • Using tweezers, remove the two rubber pads covering the screws at the top of the phone near the hinge.
  4. Disassembling LG VX8300 Body: step 4, image 1 of 2 Disassembling LG VX8300 Body: step 4, image 2 of 2
    • Remove all four 3mm Phillips #00 screws from the back of the phone.
  5. Disassembling LG VX8300 Body: step 5, image 1 of 2 Disassembling LG VX8300 Body: step 5, image 2 of 2
    • Use your fingers to gently separate the front plate from the phone. You may need to slide a plastic opening tool along the crevice between the faces to separate it more easily.
    • Remove the casing after it has been detached leaving the logic board fully accessible.
    • The volume and camera buttons are free to move around after the case has been opened. Be careful not to lose any lose pieces when continuing.
nvalm
448 Reputation
4 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 648
