Disassembling IBM ThinkPad A30 Modem and Ethernet Cards
  1. Disassembling IBM ThinkPad A30 Modem and Ethernet Cards, Battery: step 1, image 1 of 2 Disassembling IBM ThinkPad A30 Modem and Ethernet Cards, Battery: step 1, image 2 of 2
    • Flip the ThinkPad over so that it is upside down.
    • Slide the highlighted tab to the left.
    • With your finger on the tab, remove the battery by lifting it upwards away from the laptop.
  2. Disassembling IBM ThinkPad A30 Modem and Ethernet Cards, Modem and Ethernet Cards: step 2, image 1 of 2 Disassembling IBM ThinkPad A30 Modem and Ethernet Cards, Modem and Ethernet Cards: step 2, image 2 of 2
    • Remove the two 5.3mm cover screws.
    • Gently lift the cover.
  3. Disassembling IBM ThinkPad A30 Modem and Ethernet Cards: step 3, image 1 of 1
    • Remove the four 9.1mm screws attached to the ethernet and modem cards.
  4. Disassembling IBM ThinkPad A30 Modem and Ethernet Cards: step 4, image 1 of 3 Disassembling IBM ThinkPad A30 Modem and Ethernet Cards: step 4, image 2 of 3 Disassembling IBM ThinkPad A30 Modem and Ethernet Cards: step 4, image 3 of 3
    • When lifting the cards, be careful not to rip out the cables!
    • Gently lift the modem and ethernet cards.
    • Remove the cables that attach the modem and ethernet cards.
Alan
380 Reputation
6 Guides authored
Cal Poly, Team 4-44, Amido Fall 2010 Member of Cal Poly, Team 4-44, Amido Fall 2010
CPSU-AMIDO-F10S4G44
4 Members
26 Guides authored
Past 24 Hours: 4
Past 7 Days: 13
Past 30 Days: 23
All Time: 1,904
