Disassembling IBM ThinkPad 560z Upper Case
  1. Disassembling IBM ThinkPad 560z Upper Case, Battery Removal: step 1, image 1 of 1
    • Slide the battery release latch to the right.
    • Pull out the battery out towards the front of the device.
  2. Disassembling IBM ThinkPad 560z Upper Case, Upper Case: step 2, image 1 of 1
    • Remove the 7 mm Phillips #0 screws.
    • Remove the 10 mm Phillips #0 screws.
    • Remove the 14 mm Phillips #0 screw.
  3. Disassembling IBM ThinkPad 560z Upper Case: step 3, image 1 of 2 Disassembling IBM ThinkPad 560z Upper Case: step 3, image 2 of 2
    • Open the flap on the left hand side.
  4. Disassembling IBM ThinkPad 560z Upper Case: step 4, image 1 of 2 Disassembling IBM ThinkPad 560z Upper Case: step 4, image 2 of 2
    • Insert the plastic opening tools between the right and left sides of the latch.
    • Pry the right side of the latch, and then pry the left side to detach the laptop's cover.
  5. Disassembling IBM ThinkPad 560z Upper Case: step 5, image 1 of 2 Disassembling IBM ThinkPad 560z Upper Case: step 5, image 2 of 2
    • Open the flap on the right side.
  6. Disassembling IBM ThinkPad 560z Upper Case: step 6, image 1 of 1
    • Insert the plastic opening tools towards the right side of the latch.
    • Gently pry the right side out to release the top cover.
  7. Disassembling IBM ThinkPad 560z Upper Case: step 7, image 1 of 2 Disassembling IBM ThinkPad 560z Upper Case: step 7, image 2 of 2
    • Lift the keyboard slowly.
    • A cable connects the keyboard to the motherboard. If you are not careful, you will damage the cable.
  8. Disassembling IBM ThinkPad 560z Upper Case: step 8, image 1 of 1
    • Use your fingers or a spudger to detach the connector.
  9. Disassembling IBM ThinkPad 560z Upper Case: step 9, image 1 of 2 Disassembling IBM ThinkPad 560z Upper Case: step 9, image 2 of 2
    • Carefully lift and remove the keyboard.
Derek Driscoll
119 Reputation
8 Guides authored
Cal Poly, Team 26-27, Regan Spring 2010 Member of Cal Poly, Team 26-27, Regan Spring 2010
CPSU-REGAN-S10S26G27
3 Members
18 Guides authored
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 17
All Time: 1,741
