Disassembling DualShock 4 Controller
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Disassembling DualShock 4 Controller, Controller: step 1, image 1 of 1
    • Using the Phillips #00 Screwdriver, remove the four 6.0 mm screws securing the rear cover to the controller.
    • Do not forcefully loosen the screws, as it will amount to permanent damage of the threads, making removal impossible.
  2. Disassembling DualShock 4 Controller: step 2, image 1 of 3 Disassembling DualShock 4 Controller: step 2, image 2 of 3 Disassembling DualShock 4 Controller: step 2, image 3 of 3
    • Beginning with the left shoulder:
    • Pinch the left shoulder of the controller to introduce an opening.
    • Wedge a plastic opening tool into the opening and slide it up towards the joystick.
    • Pull down on the plier to crack open the casing.
    • Repeat these steps for the right shoulder.
  3. Disassembling DualShock 4 Controller: step 3, image 1 of 3 Disassembling DualShock 4 Controller: step 3, image 2 of 3 Disassembling DualShock 4 Controller: step 3, image 3 of 3
    • Wedge a plastic opening tool into the case-splittings and pull down to crack open the casing near the following buttons:
    • Share button
    • Options button
    • Split the plastic covers of the controller apart, taking note that they will still be attached by circuit board ribbons.
    • Three small pieces are often released from the framework. To prevent loss, maintain a controlled work field.
    • 2 Trigger Springs
    • 1 Grey Reset Button Extension
Mark
7,727 Reputation
7 Guides authored
Cal Poly, Team 6-21, Maness Winter 2014 Member of Cal Poly, Team 6-21, Maness Winter 2014
CPSU-MANESS-W14S6G21
4 Members
40 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 2,256
