Introduction
If your Apple IIc is having hardware problems, you will need to remove the cover to access most of the components. Use this guide for step-by-step instructions on how to safely do that.
Be sure to have a #2 phillips head screwdriver and a prying tool. Take care when prying since the plastic may be brittle.
This guide shows you how to remove the cover of an Apple IIc computer. All you need to perform this repair is a screwdriver and something to help open the casing. This is a precursor to any other repair you may want to do on this device and also allows you to get a good look at its internal workings.
Remove the six 19 mm long screws with a #2 Phillips head screwdriver.
Slide the case toward the ports on the back, then grip under the catch and pull up while moving toward the ports to remove.
