Introduction
If your Apple IIc is having hardware problems, you will need to remove the cover to access most of the components. Use this guide for step-by-step instructions on how to safely do that.
This guide shows you how to remove the cover of an Apple IIc computer. All you need to perform this repair is a screwdriver and something to help open the casing. This is a precursor to any other repair you may want to do on this device and also allows you to get a good look at its internal workings.
Remove the six 19 mm long screws with a #2 Phillips head screwdriver.
Slide the case toward the ports on the back, then grip under the catch and pull up while moving toward the ports to remove.
