Disassembling Apple AirPort Extreme Base Station Model A1034
  1. Disassembling Apple AirPort Extreme Base Station Model A1034, Disassembling Apple AirPort Extreme Base Station Model A1034: step 1, image 1 of 1
    • Remove the three 5mm T7 Torx screws from the back panel.
  2. Disassembling Apple AirPort Extreme Base Station Model A1034: step 2, image 1 of 1
    • Remove one 5mm phillips screw located under the identification sticker. You will need to remove the sticker or make a hole to get to the screw.
  3. Disassembling Apple AirPort Extreme Base Station Model A1034: step 3, image 1 of 1
    • Separate the bottom and top casings.
  4. Disassembling Apple AirPort Extreme Base Station Model A1034: step 4, image 1 of 2 Disassembling Apple AirPort Extreme Base Station Model A1034: step 4, image 2 of 2
    • Remove the metal case from the top case of the AirPort, there are no screws holding it on.
    • Remove the four screws from the metal casing.
Michael Garcia
411 Reputation
5 Guides authored
Cal Poly, Team 17-15, Regan Fall 2011 Member of Cal Poly, Team 17-15, Regan Fall 2011
CPSU-REGAN-F11S17G15
3 Members
13 Guides authored
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 31
All Time: 2,750
