Desktop PC Left Panel Replacement
  1. Desktop PC Left Panel Replacement, Left Panel: step 1, image 1 of 1
    • Unplug the computer from the power supply before any maintenance or disassembly.
    • Remove the two Phillips #2 head 5mm screws from the back side of the computer case. You only need to remove the screws that hold down the panel.
    • These screws can usually be removed by hand.
    • Be sure to wear an anti-static bracelet or use and anti-static mat to ensure important components are not damaged by static electricity.
  2. Desktop PC Left Panel Replacement: step 2, image 1 of 2 Desktop PC Left Panel Replacement: step 2, image 2 of 2
    • Next, remove the side panel of the computer case to allow access into the computer. Slide the panel towards the back of the computer and lift it up to remove.
    • If there is a fan mounted on the side panel, make sure to unplug the cable before fully removing the panel.
David Lennon
9,944 Reputation
10 Guides authored
Cal Poly, Team 4-5, Maness Spring 2015 Member of Cal Poly, Team 4-5, Maness Spring 2015
CPSU-MANESS-S15S4G5
4 Members
45 Guides authored
Past 24 Hours: 7
Past 7 Days: 29
Past 30 Days: 83
All Time: 5,379
