Introduction
This guide will allow you to replace the keyboard completely. You may need to remove this in order to replace the screen.
Pry up the top of the cover first by using a spudger to wedge in between the cover and base of the computer.
Once the spudger is between the cover and the base of the computer, wedge underneath the remaining border surrounding the keyboard.
Unhook the cables connected to the mouse pad by flipping up the black tabs that hold either cable in place.
Using a spudger, slowly open up the two black clips holding down both cables.
Separate the now unfastened cables from the base of the computer.
Once the cables are detached from the keyboard, you may pull the keyboard away completely and set it aside.
