Dell XPS 13 Solid State Drive (SSD) Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. Dell XPS 13 Solid State Drive (SSD) Replacement, Back Cover: step 1, image 1 of 2 Dell XPS 13 Solid State Drive (SSD) Replacement, Back Cover: step 1, image 2 of 2
    • Remove the eight 4 mm T5 Torx screws from the bottom cover.
  2. Dell XPS 13 Solid State Drive (SSD) Replacement: step 2, image 1 of 2 Dell XPS 13 Solid State Drive (SSD) Replacement: step 2, image 2 of 2
    • Use a plastic opening tool to pry open the 'XPS' flap in the middle.
  3. Dell XPS 13 Solid State Drive (SSD) Replacement: step 3, image 1 of 1
    • Remove the single Phillips screw hidden beneath the flap.
  4. Dell XPS 13 Solid State Drive (SSD) Replacement: step 4, image 1 of 1
    • Use opening picks or a plastic pry tool to pry open the case clips, beginning from the back edge.
  5. Dell XPS 13 Solid State Drive (SSD) Replacement: step 5, image 1 of 1
    • Remove the bottom cover.
  6. Dell XPS 13 Solid State Drive (SSD) Replacement, Solid State Drive (SSD): step 6, image 1 of 1
    • Remove the black, 4 mm Phillips #000 screw on the right of the SSD.
    • The SSD card will pop up at a 45-degree angle after the screw is removed.
  7. Dell XPS 13 Solid State Drive (SSD) Replacement: step 7, image 1 of 2 Dell XPS 13 Solid State Drive (SSD) Replacement: step 7, image 2 of 2
    • Gently lift the SSD card with your hand to pull it up and to the right.
3 other people completed this guide.
Jay
261 Reputation
2 Guides authored
Cal Poly, Team S21-G6, Livingston Spring 2017 Member of Cal Poly, Team S21-G6, Livingston Spring 2017
CPSU-LIVINGSTON-S17S21G6
5 Members
30 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 16
All Time: 2,479
