Dell XPS 13 9300 Battery Replacement
  1. Dell XPS 13 9300 Battery Replacement, Battery: step 1, image 1 of 1
    • Be sure to power off and unplug your device before you begin your repair.
    • Use a Torx T5 screwdriver to remove the eight screws that secure the base cover to the palm-rest and keyboard assembly
  2. Dell XPS 13 9300 Battery Replacement: step 2, image 1 of 1
    • Starting from the bottom-left corner, use a spudger to pry the base cover in the direction of the arrows to release the base cover from the palm-rest and keyboard assembly.
  3. Dell XPS 13 9300 Battery Replacement: step 3, image 1 of 1
    • Hold both sides of the base cover and lift to remove the base cover from the laptop.
    • The pins at the bottom of the base cover for grounding the antennas and the audio board are fragile. Place the base cover on a clean surface to avoid damage to the pins
  4. Dell XPS 13 9300 Battery Replacement: step 4, image 1 of 1
    • Using the pull tab, disconnect the battery cable from the system board.
  5. Dell XPS 13 9300 Battery Replacement: step 5, image 1 of 1
    • Use a Phillips screwdriver to remove the five screws securing the battery.
    • Lift and remove the battery.
    • Hold the laptop's power button down for 15 seconds to drain any residual power from the laptop.
iFixit Member of iFixit
Staff
136 Members
17,430 Guides authored
Past 24 Hours: 5
Past 7 Days: 43
Past 30 Days: 245
All Time: 11,305
