Dell Vostro 3561 Memory Module Replacement
  1. Dell Vostro 3561 Memory Module Replacement, Sliding the Battery Release Latch: step 1, image 1 of 1
    • Flip the computer over.
    • Slide the battery release latch to the unlock position.
  2. Dell Vostro 3561 Memory Module Replacement, Slide the Battery Release Latch: step 2, image 1 of 1
    • Slide the other battery release latch to the unlock position.
  3. Dell Vostro 3561 Memory Module Replacement, Removing the Battery: step 3, image 1 of 1
    • Slide the battery and remove it from the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  4. Dell Vostro 3561 Memory Module Replacement, Remove the Screws: step 4, image 1 of 1
    • Remove the screws that secure the base cover to the computer.
  5. Dell Vostro 3561 Memory Module Replacement, Removing the Base Cover: step 5, image 1 of 1
    • Lift up the base cover and remove it from the computer.
  6. Dell Vostro 3561 Memory Module Replacement, Releasing the Memory Module: step 6, image 1 of 1
    • Push apart the memory retention clips to release the memory module.
  7. Dell Vostro 3561 Memory Module Replacement: step 7, image 1 of 1
    • Remove the memory module from its connector on the system board.
Johnathan Hammond
44,989 Reputation
408 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
42 Members
1,989 Guides authored
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 12
All Time: 475
