Dell Vostro 3510 RAM Replacement
    1. Dell Vostro 3510 RAM Replacement, Battery: step 1, image 1 of 2 Dell Vostro 3510 RAM Replacement, Battery: step 1, image 2 of 2
      • Ensure the laptop is powered off.
      • Flip the laptop over.
      Ask FixBot
    2. Dell Vostro 3510 RAM Replacement: step 2, image 1 of 1
      Tool used on this step:
      Magnetic Project Mat
      $19.95
      Buy
      • Use a Phillips #0 screwdriver to remove the screws highlighted with red circles.
      • Loosen the two 1 mm captive screws (orange circles in the image) on the back corners of the bottom cover.
      • Keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your laptop.
      Ask FixBot
    3. Dell Vostro 3510 RAM Replacement: step 3, image 1 of 2 Dell Vostro 3510 RAM Replacement: step 3, image 2 of 2
      • Open up the back cover of the laptop.
      • It is much easier to open up the laptop with any type of spudger or with Jimmy.
      Ask FixBot
    4. Dell Vostro 3510 RAM Replacement: step 4, image 1 of 2 Dell Vostro 3510 RAM Replacement: step 4, image 2 of 2
      • Remove the battery cable from the motherboard by lightly pulling on the black tape attached to the ribbon cable.
      Ask FixBot
    5. Dell Vostro 3510 RAM Replacement: step 5, image 1 of 1
      • Use a Phillips #0 screwdriver to remove the three battery screws.
      • Carefully move the additional sata storage ribbon cable to the side.
      Ask FixBot
    6. Dell Vostro 3510 RAM Replacement: step 6, image 1 of 1
      • Gently remove the battery from the laptop.
      • Be careful with the other ribbon cables.
      Ask FixBot
    1. Dell Vostro 3510 RAM Replacement, RAM: step 7, image 1 of 2 Dell Vostro 3510 RAM Replacement, RAM: step 7, image 2 of 2
      • Use your fingers to gently push the clips outward until the RAM module pops up slightly.
      • Don't use excessive force, as this may damage the clips.
      Ask FixBot
    2. Dell Vostro 3510 RAM Replacement: step 8, image 1 of 2 Dell Vostro 3510 RAM Replacement: step 8, image 2 of 2
      • Avoid bending or twisting the RAM to prevent damage.
      • Gently slide the RAM module out of its socket.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 76
All Time: 364
