Dell Vostro 3500 CMOS Battery Replacement
  1. Dell Vostro 3500 CMOS Battery Replacement, Sliding the Battery Latch: step 1, image 1 of 1
    • Flip the computer over.
    • Slide the battery release latch to the unlock position.
  2. Dell Vostro 3500 CMOS Battery Replacement, Sliding the Battery Release Latch: step 2, image 1 of 1
    • Slide the other battery release latch to the unlock position.
  3. Dell Vostro 3500 CMOS Battery Replacement, Removing the Battery: step 3, image 1 of 1
    • Slide the battery and remove it from the computer.
  4. Dell Vostro 3500 CMOS Battery Replacement, Remove the Screws: step 4, image 1 of 1
    • Turn the laptop over and remove two screws securing the service cover.
  5. Dell Vostro 3500 CMOS Battery Replacement, Removing the Base Cover: step 5, image 1 of 1
    • Prise up the service cover and remove it from the computer. Clips along the edges can be snapped open except for those on the left hand edge (as shown in the photo) which have to be disengaged after all the others by romoving the cover in the direction shown.
    • On resassembly, insert the clips on the left hand edge then snap all te others home by applying firm pressure along the other edges of the cover.
  6. Dell Vostro 3500 CMOS Battery Replacement, CMOS battery removal: step 6, image 1 of 1
    • Locate the CMOS battery
    • Gently disengage its connector.
    • Do not disengage the connector by pulling the leads as you may tear them out of the connector. Instead, pull on the connector itself, ideally with a pair of tweezers, rocking it back and forth alternately in the directions of the red and black leads.
Philip Le Riche
30,089 Reputation
47 Guides authored
Restart Project Member of Restart Project
Community
19 Members
510 Guides authored
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 24
All Time: 2,197
