Introduction
If your screen is cracked, broken, doesn't respond to touch, or has broken pixels, it might be time to replace the screen. This guide will help you to replace the screen on the Dell Venue 8
Hold the device with the screen facing up. Gently wedge your plastic opening tool into the crease, and run it along the perimeter of the case
Remove the back panel of the device.
Remove the 14 screws with the T-5 Torx screwdriver. (11 black 3.6mm screws, and three 4.45mm screws)
4.45mm Silver screws
3.6mm Black screws
Gently snap the perimeter clips open, and remove the internal plastic case.
Unclip the power clip from the motherboard by pulling down gently towards the bottom of the tablet.
Remove the speaker by placing using your plastic opening tool in the gap on the top of the speaker and prying it up.
Disconnect the display clip found next to the speaker.
Disconnect the Display connection located at the top of the tablet.
