Dell Streak 7 Motherboard Replacement
  1. Dell Streak 7 Motherboard Replacement, Front Panel Assembly: step 1, image 1 of 1
    • Insert the spudger under the capacitive button panel, and slide the spudger all the way around.
    • You will want to heat up the screen edges with the iOpener to help facilitate removal.
  2. Dell Streak 7 Motherboard Replacement: step 2, image 1 of 1
    • Remove the button cover by lifting the cover away from the tablet.
  3. Dell Streak 7 Motherboard Replacement: step 3, image 1 of 1
    • Using the Torx screwdriver, remove the 4mm screws.
  4. Dell Streak 7 Motherboard Replacement: step 4, image 1 of 1
    • With the Torx screwdriver, remove the two 5mm screws.
  5. Dell Streak 7 Motherboard Replacement: step 5, image 1 of 2 Dell Streak 7 Motherboard Replacement: step 5, image 2 of 2
    • Using the spudger, insert it under the black side panel. Slide the spudger all the way around until the cover piece comes off.
    • With the Torx screwdriver, remove the two 4mm screws.
  6. Dell Streak 7 Motherboard Replacement: step 6, image 1 of 1
    • Use the spudger to go along the edges of the device and pop out the latches securing the display to the case.
  7. Dell Streak 7 Motherboard Replacement: step 7, image 1 of 2 Dell Streak 7 Motherboard Replacement: step 7, image 2 of 2
    • Ribbon cables are very sensitive and prone to breaking
    • Disconnect the ribbon cables by unlocking the connector and pulling the cable out slowly.
    • Make sure all the cables are unplugged before opening the device completely. Failure to do so might lead to broken or torn cables.
  8. Dell Streak 7 Motherboard Replacement, Headphone Jack: step 8, image 1 of 1
    • Using the spudger, disconnect the ribbon cable by lifting up on the connector.
    • Ribbon cables are fragile and easily broken.
  9. Dell Streak 7 Motherboard Replacement: step 9, image 1 of 2 Dell Streak 7 Motherboard Replacement: step 9, image 2 of 2
    • Pull the headphone jack up, away from the case.
  10. Dell Streak 7 Motherboard Replacement, GSM Module: step 10, image 1 of 2 Dell Streak 7 Motherboard Replacement, GSM Module: step 10, image 2 of 2
    • With the spudger, disconnect the antenna cable located on the module.
  11. Dell Streak 7 Motherboard Replacement: step 11, image 1 of 2 Dell Streak 7 Motherboard Replacement: step 11, image 2 of 2
    • Using tweezers, remove the tape connected to the GSM module.
  12. Dell Streak 7 Motherboard Replacement: step 12, image 1 of 2 Dell Streak 7 Motherboard Replacement: step 12, image 2 of 2
    • Remove the two 3mm screws securing the GSM module. Use the Torx screwdriver.
  13. Dell Streak 7 Motherboard Replacement: step 13, image 1 of 1
    • Disconnect the GSM module by lifting the module up, out of the case.
  14. Dell Streak 7 Motherboard Replacement, Motherboard: step 14, image 1 of 3 Dell Streak 7 Motherboard Replacement, Motherboard: step 14, image 2 of 3 Dell Streak 7 Motherboard Replacement, Motherboard: step 14, image 3 of 3
    • Using the spudger, disconnect the front camera by lifting up on the connector.
  15. Dell Streak 7 Motherboard Replacement: step 15, image 1 of 1
    • Using the Torx screwdriver, remove the six 3mm screws .
  16. Dell Streak 7 Motherboard Replacement: step 16, image 1 of 2 Dell Streak 7 Motherboard Replacement: step 16, image 2 of 2
    • Lift up the metal cover.
  17. Dell Streak 7 Motherboard Replacement: step 17, image 1 of 1
    • Use the spudger to lift the vibration motor out of the case.
  18. Dell Streak 7 Motherboard Replacement: step 18, image 1 of 1
    • Pull out the motherboard and the battery.
2 other people completed this guide.
Jair Garcia Varela
301 Reputation
2 Guides authored
USF Tampa, Team 4-6, Passmore Fall 2016 Member of USF Tampa, Team 4-6, Passmore Fall 2016
USFT-PASSMORE-F16S4G6
3 Members
12 Guides authored
One Comment
do you know any website or if you guys even sell the board to him
leonardo_hitman - Reply
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 3
All Time: 321
