Dell Precision 3541 SSD Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
19
Past 30 Days:
74
All Time:
254
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 25 minutes
Difficulty: Easy
Confusing Text
Some of this guide's text is confusing, duplicated, or off-topic. Clarify it by editing!
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Needs More Images
A few more images would make this guide's procedures crystal clear.
Missing Steps
Oops! This guide is currently missing one or more important steps.
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
This guide is meant to walk you through the basic steps of replacing an SSD in a simple and clear way. Before you begin, make sure your device is powered off and unplugged to avoid any damage or safety issues.
Tools
    1. Dell Precision 3541 SSD Replacement, SSD: step 1, image 1 of 2 Dell Precision 3541 SSD Replacement, SSD: step 1, image 2 of 2
      • The first step for SSD replacement is to remove the base cover which is the bottom panel of the device. You will find a total of eight small screws, three on each side, and two in the middle of the panel. Once all screws are removed, it may be helpful to use a flat, pointy tool such as a paint key, to pop the panel off of the device.
      Ask FixBot
    2. Dell Precision 3541 SSD Replacement: step 2, image 1 of 2 Dell Precision 3541 SSD Replacement: step 2, image 2 of 2
      • Now, you can locate the SSD. It is a rectangular component, about 3 inches in length. It will be embedded into the left-ward side of the underbody, almost exactly in the center latitudinally. The SSD drive will have two screws holding it in place, one on the top left, and another on the right side. Once unscrewed, the SSD can be carefully removed.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Abby Lunday
279 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 19
Past 30 Days: 74
All Time: 254
