Dell Precision 3541 Battery Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
25
Past 30 Days:
97
All Time:
314
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Confusing Text
Some of this guide's text is confusing, duplicated, or off-topic. Clarify it by editing!
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Introduction
Go to step 1 ↓
The Dell Precision 3541 internally houses a rechargeable lithium-ion battery located inside of the chassis, otherwise known as “underbody”. The battery might require replacement for a number of reasons, caused by degradation hindering performance quality. The following steps describe the process for battery removal in cases of needed replacement.
Before you begin, power off and unplug your device to avoid any damage or safety issues.
Tools
    1. Dell Precision 3541 Battery Replacement, Battery: step 1, image 1 of 3 Dell Precision 3541 Battery Replacement, Battery: step 1, image 2 of 3 Dell Precision 3541 Battery Replacement, Battery: step 1, image 3 of 3
      • The first step for battery replacement is to remove the base cover which is the bottom panel of the device. You will find a total of eight small screws, three on each side, and two in the middle of the panel. Once all screws are removed, it may be helpful to use a flat, pointy tool such as a paint key, to pop the panel off of the device.
      Ask FixBot
    2. Dell Precision 3541 Battery Replacement: step 2, image 1 of 2 Dell Precision 3541 Battery Replacement: step 2, image 2 of 2
      • Once looking at the interior of the underbody, you should find a rectangular encasement panel in the bottom right corner of the device. This component is the battery. On the battery, you will find one screw on the right side and two on the top. Unscrew all three carefully, putting them in a safe holding place.
      Ask FixBot
    3. Dell Precision 3541 Battery Replacement: step 3, image 1 of 3 Dell Precision 3541 Battery Replacement: step 3, image 2 of 3 Dell Precision 3541 Battery Replacement: step 3, image 3 of 3
      • Locate a small black cable that runs along a crevice in the underside of the battery that connects the bottom of the battery to the device. Carefully unplug the side that connects into the battery and remove the cable from its crevice. Then the battery can be removed.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Abby Lunday
279 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 25
Past 30 Days: 97
All Time: 314
