Dell Latitude D620 RAM Replacement
  1. Dell Latitude D620 RAM Replacement, Keyboard: step 1, image 1 of 1
    • Power down the laptop and remove the battery.
    • Open the laptop cover all of the way.
  2. Dell Latitude D620 RAM Replacement: step 2, image 1 of 3 Dell Latitude D620 RAM Replacement: step 2, image 2 of 3 Dell Latitude D620 RAM Replacement: step 2, image 3 of 3
    • Locate the notch under the cover at the top of the keyboard
    • Using the spudger as a lever, lift the plastic covering
    • Carefully remove the rest of the covering from right to left
  3. Dell Latitude D620 RAM Replacement: step 3, image 1 of 1
    • Unscrew the top portion of the keyboard using a #00 screwdriver
  4. Dell Latitude D620 RAM Replacement: step 4, image 1 of 1
    • Hold keyboard from the top and gently pull towards the LCD screen to remove the keyboard from the case
    • Don't pull on the keyboard too forcefully because it is attached to the motherboard with a short, thin ribbon cable
  5. Dell Latitude D620 RAM Replacement: step 5, image 1 of 2 Dell Latitude D620 RAM Replacement: step 5, image 2 of 2
    • Once keyboard is out of the case, lay it face-down on the track pad
  6. Dell Latitude D620 RAM Replacement: step 6, image 1 of 2 Dell Latitude D620 RAM Replacement: step 6, image 2 of 2
    • Using a small spudger, pull back on the black bar to release the blue lever
  7. Dell Latitude D620 RAM Replacement: step 7, image 1 of 1
    • Pull up on the metal bar connected to the socket to detach the ribbon cable
  8. Dell Latitude D620 RAM Replacement, RAM: step 8, image 1 of 2 Dell Latitude D620 RAM Replacement, RAM: step 8, image 2 of 2
    • With the keyboard removed, you should be able to see ram slot A.
    • Place new ram into the slot making sure it is aligned
  9. Dell Latitude D620 RAM Replacement: step 9, image 1 of 1
    • Replace the keyboard by following the previous steps in reverse
    • Close the laptop, and flip it over onto its backside
  10. Dell Latitude D620 RAM Replacement: step 10, image 1 of 2 Dell Latitude D620 RAM Replacement: step 10, image 2 of 2
    • Loosen the screw that holds the RAM cover in place.
    • The screw cannot be fully removed since it is attached to the RAM cover.
  11. Dell Latitude D620 RAM Replacement: step 11, image 1 of 2 Dell Latitude D620 RAM Replacement: step 11, image 2 of 2
    • Insert new ram into slot B
Miguel Wong
562 Reputation
3 Guides authored
Cal Poly, Team 24-35, Regan Spring 2010 Member of Cal Poly, Team 24-35, Regan Spring 2010
CPSU-REGAN-S10S24G35
4 Members
4 Guides authored
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 33
All Time: 34,285
