Introduction
If your Dell Latitude 3420 is running slow, freezing during multitasking, or struggling to open programs, you may need to upgrade or replace the RAM. The RAM modules control how much data your laptop can handle at once. When they begin to get old or are too small for what you need, the performance drops fast. This repair involves removing the bottom cover, releasing the existing RAM from its slot, and installing a new module. Make sure the new RAM is seated firmly before closing the laptop again.
Close the laptop lid and set the laptop down with the lower case facing you.
Use a Phillips #00 screwdriver to remove the seven 7 mm-long screws securing the lower case.
Two clips secure each RAM module in place, one on each side. Using your fingers, spread the clips away from the RAM module.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
