Dell Inspiron E1505 Wireless Card Replacement
  1. Dell Inspiron E1505 Wireless Card Replacement, Battery: step 1, image 1 of 1
    • Before any work can be done ensure that the laptop is powered off.
    • Use either the power button on the computer or issue a shutdown from the operating system.
    • Once the device is off place the laptop on a flat surface and flip it so that the bottom is facing upwards.
  2. Dell Inspiron E1505 Wireless Card Replacement: step 2, image 1 of 1
    • Locate the battery release switch on the bottom of the laptop.
    • Once located slide the switch into the unlock position.
  3. Dell Inspiron E1505 Wireless Card Replacement: step 3, image 1 of 1
    • Locate the “lip” on the laptop to lift the battery outside of the compartment.
    • Once the battery is out, you will be able to find the replacement part number in order to purchase a new battery.
  4. Dell Inspiron E1505 Wireless Card Replacement: step 4, image 1 of 1
    • Once the new battery has been acquired take the battery and place it in the empty battery slot.
    • Slide the switch into the lock position to secure the new battery.
  5. Dell Inspiron E1505 Wireless Card Replacement, Back Door removal: step 5, image 1 of 1
    • On the back of the laptop there is a compartment for the modem for easy access.
    • It is located right above the switch for the battery and has two phillips head screws as well as a sticker for the laptops product key.
    • Unscrew the two screws with a screwdriver and lift the backplate up to unveil the Modem.
  6. Dell Inspiron E1505 Wireless Card Replacement: step 6, image 1 of 1
    • There are two metal tabs on each of the sticks of phone modem.
    • Press each of the tabs outward and the modem stick should slide up.
    • Gently pull the stick of phone modem out and get the product number to get replacement modem.
    • Do this for both of the sticks of phone modem.
  7. Dell Inspiron E1505 Wireless Card Replacement, Inserting a new modem: step 7, image 1 of 1
    • Inserting new Wireless Card: Line up the Wireless Card by making sure the slot on the Wireless Card stick lines up with the slot on the laptop.
    • Insert it at slight angle while it lined up.
    • Gently press the stick of Wireless Card down until the two metal tabs snap it back in.
    • Repeat this as necessary.
Onelis Ivette Sanchez
168 Reputation
1 Guide authored
UMass Dartmouth, Team 6-7, Martin Fall 2016 Member of UMass Dartmouth, Team 6-7, Martin Fall 2016
UMASSD-MARTIN-F16S6G7
3 Members
4 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 21
All Time: 455
