Before any work can be done ensure that the laptop is powered off.
  • Before any work can be done ensure that the laptop is powered off.
  • Use either the power button on the computer or issue a shutdown from the operating system.
  • Once the device is off place the laptop on a flat surface and flip it so that the bottom is facing upwards.
Locate the battery release switch on the bottom of the laptop.
  • Locate the battery release switch on the bottom of the laptop.
  • Once located slide the switch into the unlock position.
  • Locate the “lip” on the laptop to lift the battery outside of the compartment.
  • Once the battery is out, you will be able to find the replacement part number in order to purchase a new battery.
  • Once the new battery has been acquired take the battery and place it in the empty battery slot.
  • Slide the switch into the lock position to secure the new battery.
  • On the back of the laptop there is a compartment for the modem for easy access.
  • It is located right above the switch for the battery and has two phillips head screws as well as a sticker for the laptops product key.
  • Unscrew the two screws with a screwdriver and lift the backplate up to unveil the Modem.
  • There are two metal tabs on each of the sticks of the modem.
  • Press each of the tabs outward and the modem stick should slide up.
  • Gently pull the stick of phone modem out and get the product number to get replacement modem.
  • Do this for both of the sticks of phone modem.
  • Installing a new modem: Line up the new modem by making sure the slot where the modem is installed lines up with the position of the connector on the new modem.
  • Push the modem down. Make sure to do this evenly so the modem makes a good connection.
  • Repeat this procedure until the modem is secure.
Onelis Ivette Sanchez
160 Reputation
1 Guide authored
UMass Dartmouth, Team 6-7, Martin Fall 2016 Member of UMass Dartmouth, Team 6-7, Martin Fall 2016
UMASSD-MARTIN-F16S6G7
3 Members
4 Guides authored
One Comment
That is not the wireless card. That is the phone modem. The wireless card is a mini PCI-e card located directly under the backspace key.
George A. - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 103
