Dell Inspiron 3148 Keyboard Replacement
    1. Dell Inspiron 3148 Keyboard Replacement, Back Panel: step 1, image 1 of 2 Dell Inspiron 3148 Keyboard Replacement, Back Panel: step 1, image 2 of 2
      • Ensure the device is powered off and unplugged. Close the device and orient it face up, with the hinges further away from you.
      • Flip the device over so the backside is facing you.
      Ask FixBot
    2. Dell Inspiron 3148 Keyboard Replacement: step 2, image 1 of 1
      • Using the Phillips #1 screwdriver, remove all nine 7mm screws.
      Ask FixBot
    3. Dell Inspiron 3148 Keyboard Replacement: step 3, image 1 of 2 Dell Inspiron 3148 Keyboard Replacement: step 3, image 2 of 2
      • Using the plastic opening tool, pull the back panel upward. Move the opening tool along the edge of the device and lift the panel off of your device.
      • Be aware, the back panel is kept in place by magnetic clips. They will offer some resistance, but continue to gently leverage upwards.
      Ask FixBot
    1. Dell Inspiron 3148 Keyboard Replacement, Battery: step 4, image 1 of 1
      • Remove the three 4mm screws holding battery in place using the Phillips #0 screwdriver.
      Ask FixBot
    2. Dell Inspiron 3148 Keyboard Replacement: step 5, image 1 of 1
      • Using the iFixit opening tools, lift the battery out of its housing.
      Ask FixBot
    3. Dell Inspiron 3148 Keyboard Replacement: step 6, image 1 of 1
      • Once loosened, use your fingers to lift the battery up and out of its housing.
      • There is a small cable which sits in a rut in the top of the battery. Ensure that it is pushed out of the way before removing completely.
      Ask FixBot
    4. Dell Inspiron 3148 Keyboard Replacement: step 7, image 1 of 1
      • Remove the battery completely.
      Ask FixBot
    1. Dell Inspiron 3148 Keyboard Replacement, RAM: step 8, image 1 of 1
      • Locate the RAM chips on the motherboard.
      Ask FixBot
    2. Dell Inspiron 3148 Keyboard Replacement: step 9, image 1 of 1
      • There are two tabs on either side of the RAM chip. Pull them away from the chip.
      Ask FixBot
    3. Dell Inspiron 3148 Keyboard Replacement: step 10, image 1 of 2 Dell Inspiron 3148 Keyboard Replacement: step 10, image 2 of 2
      • The RAM chip will pop up out of the slot.
      • Pinch the RAM between two fingers, making minimal contact. Gently pull away from its port.
      • Remove the RAM from the device.
      Ask FixBot
    1. Dell Inspiron 3148 Keyboard Replacement, Hard Drive: step 11, image 1 of 3 Dell Inspiron 3148 Keyboard Replacement, Hard Drive: step 11, image 2 of 3 Dell Inspiron 3148 Keyboard Replacement, Hard Drive: step 11, image 3 of 3
      • If there is a piece of tape connecting the hard drive and a small power cord, remove the tape.
      • Using the Phillips #0 screwdriver, remove the two 4mm screws.
      Ask FixBot
    2. Dell Inspiron 3148 Keyboard Replacement: step 12, image 1 of 3 Dell Inspiron 3148 Keyboard Replacement: step 12, image 2 of 3 Dell Inspiron 3148 Keyboard Replacement: step 12, image 3 of 3
      • Notice: there is a small data cable connecting the hard drive to the motherboard. Do not attempt to lift the hard drive all the way out before removing this cable.
      • Lift the hard drive slightly out of the device.
      • Grasp the head of the cable, not the cable itself.
      • Pull away from the hard drive, removing the data cable. The hard drive may now be fully removed.
      Ask FixBot
    1. Dell Inspiron 3148 Keyboard Replacement, Fan: step 13, image 1 of 3 Dell Inspiron 3148 Keyboard Replacement, Fan: step 13, image 2 of 3 Dell Inspiron 3148 Keyboard Replacement, Fan: step 13, image 3 of 3
      • If there is tape on your fan, remove the tape.
      • Remove the two 2mm screws on the fan enclosure using the Phillips #00 screwdriver.
      Ask FixBot
    2. Dell Inspiron 3148 Keyboard Replacement: step 14, image 1 of 2 Dell Inspiron 3148 Keyboard Replacement: step 14, image 2 of 2
      • Unscrew the three 4mm screws holding down the heat sink of the fan using the Phillips #00 screwdriver.
      • The three 4mm screws found in the heat sink will remain attached to the heat sink. This is okay as long as they are detached from the motherboard.
      Ask FixBot
    3. Dell Inspiron 3148 Keyboard Replacement: step 15, image 1 of 1
      Tool used on this step:
      Buy
      • Use the tweezers to gently pull the power supply cable from its port.
      Ask FixBot
    4. Dell Inspiron 3148 Keyboard Replacement: step 16, image 1 of 1
      • Grasp the fan and lift upward. Remove the fan from the device.
      Ask FixBot
    1. Dell Inspiron 3148 Keyboard Replacement, CMOS Battery: step 17, image 1 of 3 Dell Inspiron 3148 Keyboard Replacement, CMOS Battery: step 17, image 2 of 3 Dell Inspiron 3148 Keyboard Replacement, CMOS Battery: step 17, image 3 of 3
      Buy
      • Using a pair of tweezers, lift the exposed edge of the CMOS battery upward.
      • Once the CMOS battery has been loosened, remove it from the device.
      Ask FixBot
    1. Dell Inspiron 3148 Keyboard Replacement, Motherboard: step 18, image 1 of 1
      • Remove the keyboard cable from its ZIF connector by flipping up the locking tab on the connector and then pulling the cable out.
      Ask FixBot
    2. Dell Inspiron 3148 Keyboard Replacement: step 19, image 1 of 1
      • Remove the touch pad cable from its ZIF connector.
      Ask FixBot
    3. Dell Inspiron 3148 Keyboard Replacement: step 20, image 1 of 1
      • Remove one 3.41mm screw using a Phillips #000 screwdriver.
      • Remove the two 3.41mm screws using a Phillips #000 screwdriver.
      • Remove motherboard.
      Ask FixBot
    1. Dell Inspiron 3148 Keyboard Replacement, Keyboard: step 21, image 1 of 2 Dell Inspiron 3148 Keyboard Replacement, Keyboard: step 21, image 2 of 2
      • Using a Phillips #000 screwdriver, remove single 4.1mm screw from the SD card reader board.
      • Remove the SD card reader board.
      • Remove the keyboard.
      Ask FixBot
1 Guide Comment
This guide is a joke - the last step leaves out the part about removing the paper insulation (black sheet), and then you have about 25 plastic welded posts that hold the metal shield over the keyboard. To "Remove the keyboard" as the purported author states, you'll have to break the posts, remove the shield, then hope you can get it all back in place without damage. I would have never ordered a replacement keyboard knowing this. Pure BS.....
Matty Klem - Reply Share
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 54
All Time: 611
