Introduction
It is useful to to replace the if your your computer has become slow or your programs freeze or crash.
Place the laptop on a flat stable surface.
Flip the laptop over so the underside is visible.
Locate the battery lock switch.
Slide the lock switch to the left (away from the lock symbol).
Slide the battery out away from the laptop.
Remove the one 2mm Phillips #00 screw on the module cover.
Use the plastic opening tool to lift the module cover.
Pull the metal tabs away from the RAM chip to release it from the motherboard.
Pull the chip up from the laptop.
Repeat this process for the RAM chip directly beneath the last one.
