Introduction
Follow this guide if your disk drive is damaged and needs replacement.
Place the laptop on a flat stable surface.
Flip the laptop over so the underside is visible.
Locate the battery lock switch.
Slide the lock switch to the left (away from the lock symbol).
Slide the battery out away from the laptop.
Remove the 2mm Phillips #00 screw next to the module cover.
Pull the disc drive away from the laptop.
