Dell Inspiron 1750 Optical Drive Replacement
  1. Dell Inspiron 1750 Optical Drive Replacement, Battery: step 1, image 1 of 2 Dell Inspiron 1750 Optical Drive Replacement, Battery: step 1, image 2 of 2
    • Unplug the laptop before changing the battery to avoid electric shock.
    • Place the laptop on a flat stable surface.
    • Flip the laptop over so the underside is visible.
  2. Dell Inspiron 1750 Optical Drive Replacement: step 2, image 1 of 2 Dell Inspiron 1750 Optical Drive Replacement: step 2, image 2 of 2
    • Locate the battery lock switch.
    • Slide the lock switch to the left (away from the lock symbol).
    • Slide the battery out away from the laptop.
  3. Dell Inspiron 1750 Optical Drive Replacement, Optical Drive: step 3, image 1 of 2 Dell Inspiron 1750 Optical Drive Replacement, Optical Drive: step 3, image 2 of 2
    • Remove the 2mm Phillips #00 screw next to the module cover.
    • Pull the disc drive away from the laptop.
4 other people completed this guide.
Tina Rickard
759 Reputation
5 Guides authored
Cal Poly, Team 6-3, Forte Spring 2014 Member of Cal Poly, Team 6-3, Forte Spring 2014
CPSU-FORTE-S14S6G3
5 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 937
