Introduction
This guide provides step by step instructions to remove your Dell Inspiron 13- 7359 cooling fan. You will need a phillips head #0 screwdriver and a small plastic spudger.
Unscrew and remove the 2 of the 7mm Phillips head screws holding the cooling fan in place.
Hold the cooling fan with one hand.
With the other hand, grab hold of the part of the copper heat sink that is attached to the cooling fan.
Carefully pull the cooling fan away from the attached part so that it becomes fully disconnected.
