Introduction
This guide provides step by step instructions to remove your Dell Inspiron 13- 7359 cooling fan. You will need a phillips head #0 screwdriver and a small plastic spudger.
Flip laptop over so that the bottom panel is face up.
Use a Phillips 0 screwdriver to unscrew all 10 of the 7mm Phillips head screws from the bottom panel of the laptop.
Hold the cooling fan with one hand.
With the other hand, grab hold of the part of the copper heat sink that is attached to the cooling fan.
Carefully pull the cooling fan away from the attached part so that it becomes fully disconnected.
