Dell Alienware 17 Battery Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Dell Alienware 17 Battery Replacement, Disconnecting the Battery Cable: step 1, image 1 of 1
  2. Dell Alienware 17 Battery Replacement, Remove the Screws: step 2, image 1 of 1
    • Remove the screws that secure the battery to the computer base.
  3. Dell Alienware 17 Battery Replacement, Releasing the Battery: step 3, image 1 of 2 Dell Alienware 17 Battery Replacement, Releasing the Battery: step 3, image 2 of 2
    • Using the battery cable, lift and release the battery from the tabs on the computer base.
  4. Dell Alienware 17 Battery Replacement, Opening the Display: step 4, image 1 of 1
    • Turn the computer over and open the display.
  5. Dell Alienware 17 Battery Replacement, Grounding the System Board: step 5, image 1 of 1
    • Press and hold the power button for five seconds to ground the system board.
  6. Dell Alienware 17 Battery Replacement, Slide the New Battery: step 6, image 1 of 1
    • Slide the NEW battery under the tabs on the computer base.
  7. Dell Alienware 17 Battery Replacement, Aligning the Screw Holes: step 7, image 1 of 1
    • Align the screw holes on the battery with the screw holes on the computer base.
  8. Dell Alienware 17 Battery Replacement, Replace the Screws: step 8, image 1 of 1
    • Replace the screws that secure the battery to the computer base.
  9. Dell Alienware 17 Battery Replacement, Connect the Battery Cable: step 9, image 1 of 1
    • Connect the battery cable to the system board.
Terrence15
79,161 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
42 Members
1,988 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 44
