Dell Alienware 17 Battery Replacement
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Dell Alienware 17 Battery Replacement, Disconnecting the Battery Cable: step 1, image 1 of 1
      Ask FixBot
    2. Dell Alienware 17 Battery Replacement, Remove the Screws: step 2, image 1 of 1
      • Remove the screws that secure the battery to the computer base.
      Ask FixBot
    3. Dell Alienware 17 Battery Replacement, Releasing the Battery: step 3, image 1 of 2 Dell Alienware 17 Battery Replacement, Releasing the Battery: step 3, image 2 of 2
      • Using the battery cable, lift and release the battery from the tabs on the computer base.
      Ask FixBot
    4. Dell Alienware 17 Battery Replacement, Opening the Display: step 4, image 1 of 1
      • Turn the computer over and open the display.
      Ask FixBot
    5. Dell Alienware 17 Battery Replacement, Grounding the System Board: step 5, image 1 of 1
      • Press and hold the power button for five seconds to ground the system board.
      Ask FixBot
    6. Dell Alienware 17 Battery Replacement, Slide the New Battery: step 6, image 1 of 1
      • Slide the NEW battery under the tabs on the computer base.
      Ask FixBot
    7. Dell Alienware 17 Battery Replacement, Aligning the Screw Holes: step 7, image 1 of 1
      • Align the screw holes on the battery with the screw holes on the computer base.
      Ask FixBot
    8. Dell Alienware 17 Battery Replacement, Replace the Screws: step 8, image 1 of 1
      • Replace the screws that secure the battery to the computer base.
      Ask FixBot
    9. Dell Alienware 17 Battery Replacement, Connect the Battery Cable: step 9, image 1 of 1
      • Connect the battery cable to the system board.
      Ask FixBot
Terrence15
80,137 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,277 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 15
All Time: 176
