DeWalt Jobsite DCR010 Control Panel LED Replacement
    1. DeWalt Jobsite DCR010 Control Panel LED Replacement, Case: step 1, image 1 of 3 DeWalt Jobsite DCR010 Control Panel LED Replacement, Case: step 1, image 2 of 3 DeWalt Jobsite DCR010 Control Panel LED Replacement, Case: step 1, image 3 of 3
      • Remove the eleven 15 mm screws on the corners and back of the device casing using a Phillips #2 screwdriver.
      • If you're using the iFixit tool kit, you may need to utilize the 4 mm nut driver as an extension in order to reach the deep screws on the backside of the case.
      Ask FixBot
    2. DeWalt Jobsite DCR010 Control Panel LED Replacement: step 2, image 1 of 1
      • Take the casing apart by pulling the rubber corners away from the body of the speaker.
      • Pull the top handle away from the body of the case once the corners are removed.
      Ask FixBot
    3. DeWalt Jobsite DCR010 Control Panel LED Replacement: step 3, image 1 of 3 DeWalt Jobsite DCR010 Control Panel LED Replacement: step 3, image 2 of 3 DeWalt Jobsite DCR010 Control Panel LED Replacement: step 3, image 3 of 3
      • Remove or slice the DeWalt sticker on the left side of the device in.
      • Push out the two pins on the top of the device.
      • You may need to pry at the bottom of the device, if so, use an opening tool.
      Ask FixBot
    4. DeWalt Jobsite DCR010 Control Panel LED Replacement: step 4, image 1 of 2 DeWalt Jobsite DCR010 Control Panel LED Replacement: step 4, image 2 of 2
      • Unplug the connections running between the two sides of the case by pinching the tab on the non-speaker side and pulling away from the point of attachment.
      Ask FixBot
    1. DeWalt Jobsite DCR010 Control Panel LED Replacement, Control Panel LED: step 5, image 1 of 1
      • Inside the front panel, remove the three 15 mm screws holding the control panel to the inside of the device using the Phillips #2 screwdriver.
      Ask FixBot
    2. DeWalt Jobsite DCR010 Control Panel LED Replacement: step 6, image 1 of 1
      • Detach the four rubber latches holding the control panel in place.
      • Remove the control panel from the main body of the device.
      Ask FixBot
    3. DeWalt Jobsite DCR010 Control Panel LED Replacement: step 7, image 1 of 1
      • Use the Phillips #2 screwdriver to remove the two 15 mm screws in the interior of the control panel.
      Ask FixBot
    4. DeWalt Jobsite DCR010 Control Panel LED Replacement: step 8, image 1 of 1
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Tenna Noyes
645 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 52
All Time: 179
