This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Introduction
In test mode, you can quickly test components and the touchscreen. This guide shows how to access and use it.
Turn on the device using the main power switch. Wait until it is in standby mode. The display is dark.
Open the service door. A corresponding message appears on the display.
Press and hold the Programming (P), one cup, and rinse buttons simultaneously for about 5 seconds until "SELECT TEST" appears.
Close the service door.
You now have a few seconds to determine the type of test:
For the component test: Press the Cappuccino button. "LOAD TEST MODE" appears on the display.
For the touchscreen test: Press the Caffeelatte button. "DISPLAY TEST MODE" appears on the display.
During the component test, "LOAD TEST MODE" appears on the display. Each button (except for water and rinse) triggers a test of a component. The component is displayed on the screen each time:
The heater turns on.
The pump runs.
The grinder runs.
The brew unit moves up, end position is displayed.
The brew unit moves down, end position is displayed.
The steam heater turns on.
The buttons for one cup, two cups, and cappuccino control both solenoid valves individually and together. You should hear them click.
During the touchscreen test, "DISPLAY TEST MODE" appears on the display. Each button triggers a different display: "BUTTON 0" through "BUTTON 10".
Switch off the device using the power switch to exit test mode.
3 Guide Comments
Thank you very much!!!! Perfect information!!
