Datawind Ubislate 7ci Battery Replacement
  1. Datawind Ubislate 7ci Battery Replacement, Finding a workspace: step 1, image 1 of 1
    • Be sure to repair your device on a clean surface so you are less likely to lose small parts.
  2. Datawind Ubislate 7ci Battery Replacement, Pry open your tablet: step 2, image 1 of 2 Datawind Ubislate 7ci Battery Replacement, Pry open your tablet: step 2, image 2 of 2
    • Run your prying tool along the front edge of the device to pop off the front cover.
    • Once the halves are separated your device should look like this.
    • (HINT: be careful of the device's small wiring when separating the two halves.
  3. Datawind Ubislate 7ci Battery Replacement, Removing the tape around the battery: step 3, image 1 of 3 Datawind Ubislate 7ci Battery Replacement, Removing the tape around the battery: step 3, image 2 of 3 Datawind Ubislate 7ci Battery Replacement, Removing the tape around the battery: step 3, image 3 of 3
    • Remove the black tape.
    • (HINT: be careful not to remove the tablet camera.)
    • Your tablet should look like photo 3 after you have removed the tape.
  4. Datawind Ubislate 7ci Battery Replacement, Removing the Battery: step 4, image 1 of 3 Datawind Ubislate 7ci Battery Replacement, Removing the Battery: step 4, image 2 of 3 Datawind Ubislate 7ci Battery Replacement, Removing the Battery: step 4, image 3 of 3
    • Pry off the battery, be careful not to break the battery.
    • Use soldering iron or gun to remove the battery from both its attachment points.
  5. Datawind Ubislate 7ci Battery Replacement, Replacing the Battery: step 5, image 1 of 2 Datawind Ubislate 7ci Battery Replacement, Replacing the Battery: step 5, image 2 of 2
    • Insert your replacement battery in the same spot as the old battery.
    • Tape battery into place.
  6. Datawind Ubislate 7ci Battery Replacement, Closing the Tablet: step 6, image 1 of 2 Datawind Ubislate 7ci Battery Replacement, Closing the Tablet: step 6, image 2 of 2
    • Solder the new battery to the connection points.
    • Press the back cover on firmly till it clicks
Mekides
40 Reputation
3 Guides authored
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 16
All Time: 9,034
