DJI Phantom 2 Vision Battery Replacement
    1. DJI Phantom 2 Vision Battery Replacement, Battery: step 1, image 1 of 1
      • The battery is located on the backside of the drone. You will see a large rectangular indent protruding outward.
      • The "battery" shown in the image is for illustrative purposes only. Since the original battery was missing, we constructed this one to demonstrate the repair process. The actual battery will not stick out this much.
      Ask FixBot
    2. DJI Phantom 2 Vision Battery Replacement: step 2, image 1 of 2 DJI Phantom 2 Vision Battery Replacement: step 2, image 2 of 2
      • Remove the battery from the compartment by pinching the top and bottom pressure points near the center and pulling the battery towards you.
      Ask FixBot
    3. DJI Phantom 2 Vision Battery Replacement: step 3, image 1 of 1
      • Clean the battery compartment using cotton swabs and isopropyl alcohol or pressurized air to remove any debris or dust inside.
      • Repeat these steps after every battery replacement to prevent damage to the drone’s internal components.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Dylan Ponder
386 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 93
All Time: 558
