Introduction
The DJI Mini 3 is a lightweight, highly capable drone, but like any compact quadcopter, its arms are vulnerable to damage from crashes or wear over time. A cracked or loose arm can cause unstable flight or prevent the drone from taking off altogether. Fortunately, replacing a damaged arm is a straightforward repair that does not require replacing the entire aircraft.
This Fast Fix guide will walk you step-by-step through removing a damaged rear arm for installation of a new one. The process involves opening the drone’s shell, disconnecting the arm’s wiring, and securely mounting the replacement component. With patience and a little finesse, you can get your Mini 3 back in the air in around an hour.
Didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
