Creative Ziio 7" Motherboard Replacement
  1. Creative Ziio 7" Motherboard Replacement, Back Panel: step 1, image 1 of 3 Creative Ziio 7" Motherboard Replacement, Back Panel: step 1, image 2 of 3 Creative Ziio 7" Motherboard Replacement, Back Panel: step 1, image 3 of 3
    • Remove the back panel by using the plastic opening tool to carefully pry around the panel's edges.
    • The volume control button and the top power button may fall out during this step.
  2. Creative Ziio 7" Motherboard Replacement, Motherboard: step 2, image 1 of 3 Creative Ziio 7" Motherboard Replacement, Motherboard: step 2, image 2 of 3 Creative Ziio 7" Motherboard Replacement, Motherboard: step 2, image 3 of 3
    • Remove the copper plate covering the motherboard by desoldering the ten solder points.
    • The solder point in the bottom right corner is marked but hidden by the soldering iron.
  3. Creative Ziio 7" Motherboard Replacement: step 3, image 1 of 2 Creative Ziio 7" Motherboard Replacement: step 3, image 2 of 2
    • Remove the adhesive tape covering the three wires connected to the motherboard.
    • Desolder the solder points connecting the wires to the motherboard.
  4. Creative Ziio 7" Motherboard Replacement: step 4, image 1 of 3 Creative Ziio 7" Motherboard Replacement: step 4, image 2 of 3 Creative Ziio 7" Motherboard Replacement: step 4, image 3 of 3
    • Disconnect the ribbon cable that is attached underneath the copper plate.
    • Disconnect the other ribbon cable that is connected next the copper plate in the corner of the circuit board.
  5. Creative Ziio 7" Motherboard Replacement: step 5, image 1 of 2 Creative Ziio 7" Motherboard Replacement: step 5, image 2 of 2
    • Remove the four 4mm Philips #00 screws holding the motherboard to the casing.
    • The copper plate will be removed by now. However, the picture does not show this.
  6. Creative Ziio 7" Motherboard Replacement: step 6, image 1 of 2 Creative Ziio 7" Motherboard Replacement: step 6, image 2 of 2
    • Lift up the motherboard.
    • A mesh-looking strip on the left side will be connected to the bottom of the motherboard.
    • Remove the tape on top of the strip and use tweezers or pliers to pull on the strip to unplug it.
  7. Creative Ziio 7" Motherboard Replacement: step 7, image 1 of 1
    • Remove the red and black wires with a soldering iron that are located underneath the motherboard.
    • Do not cut or damage the wires in the process. They will be needed for the new motherboard.
  8. Creative Ziio 7" Motherboard Replacement: step 8, image 1 of 1
    • Remove the old motherboard and dispose of it resposibly.
Benedict Samoy
25 Reputation
2 Guides authored
Cal Poly, Team 14-10, Maness Spring 2013 Member of Cal Poly, Team 14-10, Maness Spring 2013
CPSU-MANESS-S13S14G10
4 Members
13 Guides authored
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 9
All Time: 1,198
