Corsair Void Pro RGB Earcup Replacement
  1. Corsair Void Pro RGB Earcup Replacement, Earcup: step 1, image 1 of 1
    • Carefully remove earmuff from headphones by getting a grip under the earmuff cushion and peeling up over the lip that keeps it in place.
  2. Corsair Void Pro RGB Earcup Replacement: step 2, image 1 of 2 Corsair Void Pro RGB Earcup Replacement: step 2, image 2 of 2
    • Using the Phillips #0 screwdriver, unscrew the seven 6.4 mm screws holding the black speaker cover in place.
    • If you are disassembling the lefthand earfmuff, there will be eight 6.4 mm screws to remove.
  3. Corsair Void Pro RGB Earcup Replacement: step 3, image 1 of 2 Corsair Void Pro RGB Earcup Replacement: step 3, image 2 of 2
    • Remove and set aside the black panel, taking care to keep the wires attached.
    • The panel should lift up without much force. If the panel does not budge, carefully use the iFixit plastic opening tool to dislodge the piece.
Elizabeth Claypool
523 Reputation
1 Guide authored
Cal Poly, Team S9-G13, Maness Spring 2019 Member of Cal Poly, Team S9-G13, Maness Spring 2019
CPSU-MANESS-S19S9G13
4 Members
14 Guides authored
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 37
All Time: 3,562
