Introduction
Use this guide to remove the core assembly in the Samsung Galaxy Watch.
Remove the four Tri-point #00 screws (4.2 mm length) on the backside of the watch.
Use an opening tool to get between the back cover and the metal housing of the watch.
Carefully pry the plastic back cover open.
Lay down the watch and lift the back cover to access the sensor connector on the motherboard.
Use a spudger to disconnect the display flex cable from the motherboard.
