Coolpad Defiant Battery Replacement
  1. Coolpad Defiant Battery Replacement, Back Cover: step 1, image 1 of 2 Coolpad Defiant Battery Replacement, Back Cover: step 1, image 2 of 2
    • Turn the phone with the back cover facing towards you.
    • Carefully remove the back cover by holding one corner of the case and carefully pulling it away from the phone.
    • The plastic case and inner components can break if not pulled carefully, so pull cautiously.
  2. Coolpad Defiant Battery Replacement: step 2, image 1 of 1
    • Remove the back cover from your device.
  3. Coolpad Defiant Battery Replacement, Battery: step 3, image 1 of 1
    • Find the gap on the bottom of the battery.
    • With a tool or with your hands, pull the battery upward and set it aside safely.
    • Remember to return the battery once you are done, safely placing it in the correct position or as how you first saw it.
    • Be careful with old or damaged batteries and dispose of it appropriately
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 16
All Time: 1,450
