Shop the Holiday Gift Guide
Coolpad Defiant Battery Replacement
Views: 2.3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
14
Past 30 Days:
65
All Time:
2,329
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 - 2 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Is your device not properly turning on or charging? Consider using this guide to replace the battery in your phone.
Tools
    1. Coolpad Defiant Battery Replacement, Back Cover: step 1, image 1 of 2 Coolpad Defiant Battery Replacement, Back Cover: step 1, image 2 of 2
      • Turn the phone with the back cover facing towards you.
      • Carefully remove the back cover by holding one corner of the case and carefully pulling it away from the phone.
      • The plastic case and inner components can break if not pulled carefully, so pull cautiously.
      Ask FixBot
    2. Coolpad Defiant Battery Replacement: step 2, image 1 of 1
      • Remove the back cover from your device.
      Ask FixBot
    1. Coolpad Defiant Battery Replacement, Battery: step 3, image 1 of 1
      • Find the gap on the bottom of the battery.
      • With a tool or with your hands, pull the battery upward and set it aside safely.
      • Remember to return the battery once you are done, safely placing it in the correct position or as how you first saw it.
      • Be careful with old or damaged batteries and dispose of it appropriately
      Ask FixBot
Author
with
Johnny Boland
535 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 65
All Time: 2,329
