Introduction
You will need to access the battery compartment before you can change the battery or remove the larger back casing. To remove the battery casing, you will need a Phillips head screwdriver.
Make sure the Connect Four Electronic Handheld is off. There is no off button, so you will need to let it shut off automatically.
Take a Phillips head screwdriver and remove the (9.1mm length) #2 screw in the middle of the battery casing.
Slide the cover off and remove the battery.
