Introduction
You will need to access the battery compartment before you can change the battery or remove the larger back casing. To remove the battery casing, you will need a Phillips head screwdriver.
Make sure the Connect Four Electronic Handheld is off. There is no off button, so you will need to let it shut off automatically.
In order to remove the battery casing, take a Phillips head screwdriver and remove the (9.1mm length) #2 screw in the middle of the battery casing.
Slide the cover off and remove the battery.
