Compaq Evo N1000v Keyboard Replacement
  1. Compaq Evo N1000v Keyboard Replacement, LED Cover: step 1, image 1 of 1
    • Flip the laptop over with the rear panel facing forward.
  2. Compaq Evo N1000v Keyboard Replacement: step 2, image 1 of 1
    • Using a TR8 Torx screwdriver, remove the two T8 Torx screws that secure the LED cover to the base enclosure.
  3. Compaq Evo N1000v Keyboard Replacement: step 3, image 1 of 1
    • Flip the laptop back over with the front facing forward. Open the screen.
  4. Compaq Evo N1000v Keyboard Replacement: step 4, image 1 of 1
    • Locate the F1 and F2 keys near the top left corner of the keyboard.
  5. Compaq Evo N1000v Keyboard Replacement: step 5, image 1 of 1
    • While holding the F1 and F2 keys, insert a spudger between the keys into the notch in the LED cover. Lift up.
  6. Compaq Evo N1000v Keyboard Replacement: step 6, image 1 of 1
    • Locate the Scroll and Pause keys near the top right corner of the keyboard.
  7. Compaq Evo N1000v Keyboard Replacement: step 7, image 1 of 1
    • While holding the Scroll and Pause keys, insert a spudger between the keys into the notch in the LED cover. Lift up.
  8. Compaq Evo N1000v Keyboard Replacement: step 8, image 1 of 2 Compaq Evo N1000v Keyboard Replacement: step 8, image 2 of 2
    • Insert a spudger between the F7 and F8 keys. Lift up to remove the LED cover.
  9. Compaq Evo N1000v Keyboard Replacement, Keyboard: step 9, image 1 of 1
    • Lift the back edge of the keyboard and pull towards the screen.
  10. Compaq Evo N1000v Keyboard Replacement: step 10, image 1 of 1
    • Pull the cable and lift up to release.
  11. Compaq Evo N1000v Keyboard Replacement: step 11, image 1 of 1
    • Remove the keyboard.
kim
59 Reputation
3 Guides authored
Cal Poly, Team 29-74, Johann Spring 2010 Member of Cal Poly, Team 29-74, Johann Spring 2010
CPSU-JOHANN-S10S29G74
3 Members
14 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 16
All Time: 3,710
