Cleaning the Fan Blades
  1. Cleaning the Fan Blades, PCB (Printed Circuit Board): step 1, image 1 of 1
    • Use the Phillips #2 screwdriver to remove the four 6 mm screws by unscrewing counterclockwise.
  2. Cleaning the Fan Blades: step 2, image 1 of 1
    • Pull the front and back cover apart.
    • Be careful not to pull the front cover off completely. It holds the wires.
  3. Cleaning the Fan Blades: step 3, image 1 of 1
    • Remove the Phillips 6 mm screw that holds the circuit board to the outer shell of the fan.
    • Shock warning: Make sure the fan is unplugged before removing the circuit board.
  4. Cleaning the Fan Blades: step 4, image 1 of 1
    • Remove the top cover containing the circuit board and the wires by pulling it away from the outer shell of the fan.
  5. Cleaning the Fan Blades: step 5, image 1 of 2 Cleaning the Fan Blades: step 5, image 2 of 2
    • Remove the screws from the four corners of the circuit board.
    • Remove the circuit board from the top cover.
    • Do not touch the other side of the circuit board to avoid damaging the circuit elements.
  6. Cleaning the Fan Blades, Fan Blades: step 6, image 1 of 1
    • Follow steps 1-4 to remove the front, back, and top covers of the fan to reach the fan blades.
    • Use a cloth to clean off dust clogged in between the fan blades.
Vivian Fong
97 Reputation
1 Guide authored
Cal Poly, Team 15-46, Forte Fall 2012 Member of Cal Poly, Team 15-46, Forte Fall 2012
CPSU-FORTE-F12S15G46
5 Members
6 Guides authored
Past 24 Hours: 2
Past 7 Days: 27
Past 30 Days: 67
All Time: 10,047
