Cleaning Debris from Flywheel Screen
  1. Cleaning Debris from Flywheel Screen, Cleaning Debris from Flywheel Screen: step 1, image 1 of 3 Cleaning Debris from Flywheel Screen, Cleaning Debris from Flywheel Screen: step 1, image 2 of 3 Cleaning Debris from Flywheel Screen, Cleaning Debris from Flywheel Screen: step 1, image 3 of 3
    • Ensure the engine is off and cooled down before starting this guide.
    • Using a 5/16" socket or wrench, remove the three bolts holding the plastic cover on to the engine.
    • Lift away the plastic cover. Note that the starter is attached to the cover and will come off with it.
  2. Cleaning Debris from Flywheel Screen: step 2, image 1 of 2 Cleaning Debris from Flywheel Screen: step 2, image 2 of 2
    • Using compressed air or a rag, clean debris from the flywheel.
Ethan Narad
529 Reputation
3 Guides authored
Cal Poly, Team S25-G15, Maness Spring 2018 Member of Cal Poly, Team S25-G15, Maness Spring 2018
CPSU-MANESS-S18S25G15
4 Members
7 Guides authored
Past 24 Hours: 4
Past 7 Days: 12
Past 30 Days: 33
All Time: 909
