Classen Over Seeder TS20HD 2012 Rake Belt Replacement
    1. Classen Over Seeder TS20HD 2012 Rake Belt Replacement, Safety precautions: step 1, image 1 of 2 Classen Over Seeder TS20HD 2012 Rake Belt Replacement, Safety precautions: step 1, image 2 of 2
      • Before you begin, ensure that the machine is powered down and cool to the touch.
      • Disconnect the spark plug to prevent the engine from accidentally starting up during service:
      • Grab the plastic housing at the end of the spark plug wire.
      • Pull firmly to disconnect the wire from the spark plug.
      Ask FixBot
    2. Classen Over Seeder TS20HD 2012 Rake Belt Replacement: step 2, image 1 of 1
      • To prevent the over seeder from rolling during service, place wheel chocks behind a rear wheel.
      Ask FixBot
    1. Classen Over Seeder TS20HD 2012 Rake Belt Replacement, Tilt the over seeder: step 3, image 1 of 2 Classen Over Seeder TS20HD 2012 Rake Belt Replacement, Tilt the over seeder: step 3, image 2 of 2
      • Push down on the main handle to tilt the over seeder back on its rear wheels.
      • Place some weights on the handle, or tie the handle down, to prevent the machine from falling forward.
      Ask FixBot
    2. Classen Over Seeder TS20HD 2012 Rake Belt Replacement: step 4, image 1 of 1
      • Place a wheel chock in front of a rear tire to keep the machine in place.
      Ask FixBot
    3. Classen Over Seeder TS20HD 2012 Rake Belt Replacement, Unscrew the belt guard: step 5, image 1 of 3 Classen Over Seeder TS20HD 2012 Rake Belt Replacement, Unscrew the belt guard: step 5, image 2 of 3 Classen Over Seeder TS20HD 2012 Rake Belt Replacement, Unscrew the belt guard: step 5, image 3 of 3
      • Remove the four lock nuts securing the belt guard:
      • Two 1/2" lock nuts
      • Two 7/16" lock nuts
      • These lock nuts are recessed and require a socket extension to access.
      • Use box wrenches to hold the corresponding bolts in place as you loosen and remove the nuts.
      Ask FixBot
    4. Classen Over Seeder TS20HD 2012 Rake Belt Replacement, Remove the belt guard: step 6, image 1 of 3 Classen Over Seeder TS20HD 2012 Rake Belt Replacement, Remove the belt guard: step 6, image 2 of 3 Classen Over Seeder TS20HD 2012 Rake Belt Replacement, Remove the belt guard: step 6, image 3 of 3
      • Remove the belt guard.
      Ask FixBot
    1. Classen Over Seeder TS20HD 2012 Rake Belt Replacement, Rake Belt: step 7, image 1 of 2 Classen Over Seeder TS20HD 2012 Rake Belt Replacement, Rake Belt: step 7, image 2 of 2
      • Use your fingers to pry the belt off the drive pulley.
      • If you are having trouble, make sure that the machine is not resting on the bail bar up by the handlebars, which tightens the idler pulley.
      Ask FixBot
    2. Classen Over Seeder TS20HD 2012 Rake Belt Replacement: step 8, image 1 of 3 Classen Over Seeder TS20HD 2012 Rake Belt Replacement: step 8, image 2 of 3 Classen Over Seeder TS20HD 2012 Rake Belt Replacement: step 8, image 3 of 3
      • Squeeze the belt and unhook it from the engine pulley.
      • Remove the rake belt.
      Ask FixBot
Arthur Shi
349,468 Reputation
930 Guides authored
iFixit Member of iFixit
Staff
122 Members
86,625 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 45
All Time: 1,296
