Microsoft Surface Pro 11 SSD Replacement
  1. Microsoft Surface Pro 11 SSD Replacement, Before you begin: step 1, image 1 of 3 Microsoft Surface Pro 11 SSD Replacement, Before you begin: step 1, image 2 of 3 Microsoft Surface Pro 11 SSD Replacement, Before you begin: step 1, image 3 of 3
    • Before starting this repair, allow your Surface Pro's battery to drain below 25%. A charged battery may catch fire if damaged.
    • Unplug all cables and fully shut down your tablet.
    Ask FixBot
  2. Microsoft Surface Pro 11 SSD Replacement, Open the kickstand: step 2, image 1 of 3 Microsoft Surface Pro 11 SSD Replacement, Open the kickstand: step 2, image 2 of 3 Microsoft Surface Pro 11 SSD Replacement, Open the kickstand: step 2, image 3 of 3
    • Lay your Surface Pro screen side down and open the kickstand to about a 90‑degree angle.
    Ask FixBot
  3. Microsoft Surface Pro 11 SSD Replacement, Remove the SSD door: step 3, image 1 of 3 Microsoft Surface Pro 11 SSD Replacement, Remove the SSD door: step 3, image 2 of 3 Microsoft Surface Pro 11 SSD Replacement, Remove the SSD door: step 3, image 3 of 3
    • Use your finger to firmly press down on the SSD door indent until the door pops up.
    • Remove the SSD door.
    Ask FixBot
  4. Microsoft Surface Pro 11 SSD Replacement, Remove the SSD screw: step 4, image 1 of 2 Microsoft Surface Pro 11 SSD Replacement, Remove the SSD screw: step 4, image 2 of 2
    • Use a Torx Plus 3IP screwdriver to remove the 2.4 mm‑long screw securing the SSD.
    • Removing the SSD also functions as a battery disconnect and should be done before all major repairs.
    Ask FixBot
  5. Microsoft Surface Pro 11 SSD Replacement, Remove the SSD: step 5, image 1 of 3 Microsoft Surface Pro 11 SSD Replacement, Remove the SSD: step 5, image 2 of 3 Microsoft Surface Pro 11 SSD Replacement, Remove the SSD: step 5, image 3 of 3
    • Don't pull up at a sharp angle, or you may damage the SSD and its socket.
    • Use the flat end of a spudger to gently lift the notched edge of the SSD enough that you can grip the bottom corners with your fingers.
    • Use your fingers or tweezers to pull the SSD straight out of its socket and remove it.
    • During reassembly, getting the SSD fully inserted in its socket can be tricky. If you're having trouble, hold the SSD in place and use the flat end of a spudger to push on the notched edge.
    Ask FixBot
Once your laptop is reassembled, follow Microsoft's post SSD replacement guide.
3 other people completed this guide.
Spencer Day
196,368 Reputation
1,243 Guides authored
iFixit Member of iFixit
Staff
123 Members
28,236 Guides authored
0 Guide Comments
Past 24 Hours: 10
Past 7 Days: 88
Past 30 Days: 462
All Time: 7,345
