Fix Your Stuff
Right to Repair
Store
You're viewing a previously published version of this guide.  View latest version
Older Newer
Introduction
User will need PH00 screwdriver and plastic pry tools for this replacement guide.
  1. Rotate the camera to expose the underside of the camera.
    • Rotate the camera to expose the underside of the camera.
  2. Slide the rounded rectangle tab to the left to release the battery cover.
    • Slide the rounded rectangle tab to the left to release the battery cover.
  3. Push the small orange tab forward to release the battery      (Battery is ready for removal).
    • Push the small orange tab forward to release the battery (Battery is ready for removal).
  4. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  5. Using the Phillips 00 screwdriver, remove the two 4mm top screws above the LCD screen. Using the Phillips 00 screwdriver, remove the two 4mm top screws above the LCD screen. Using the Phillips 00 screwdriver, remove the two 4mm top screws above the LCD screen.
    • Using the Phillips 00 screwdriver, remove the two 4mm top screws above the LCD screen.
  6. Using the Phillips 00 screwdriver, remove the two 4mm side screws to the left of the LCD screen.
    • Using the Phillips 00 screwdriver, remove the two 4mm side screws to the left of the LCD screen.
  7. Using the Phillips 00 screwdriver, remove the two 4mm side screws to the left of the LCD screen.
  8. Using the Phillips 00 screwdriver, remove the three 4mm screws from the underside of the camera.
    • Using the Phillips 00 screwdriver, remove the three 4mm screws from the underside of the camera.
  9. Using the plastic pry tool, remove the back cover from camera. Using the plastic pry tool, remove the back cover from camera.
    • Using the plastic pry tool, remove the back cover from camera.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 337
